67 Directional Signal Problem - NCRS Discussion Boards
  • Ira L.
    • May 31, 2006
    • 32
    Recently my right turn signal started act strangely. When I put on the right turn signal, the front turn signal does not light, my dashboard indicator does not light but BOTH rear right side lights blink brightly. My left turn signal operates properly. Any thoughts?
    Ira Lippel
    45858
  • Wayne W.
    • April 30, 1982
    • 3605
    Re: 67 Directional Signal Problem
    Most likely the TS switch.
    • Ira L.
      • May 31, 2006
      • 32
      Thanks Wayne, if it is the TS switch, do you think it needs to be replaces or can that be fixed in the colum?
      Ira Lippel
      45858
      • Roger O.
        • September 7, 2009
        • 209
        Ira,
        Before diving into the column there is a simple check you can do to determine if your problem is in the TS switch.
        Find the TS switch connector that attaches at the lower column(8 wires in connector).
        Then find the dark blue wire (its between the brown and lt blue ) , turn your right signal on , now probe the dark blue on both sides of the connector.
        If you get 12v on the side going to the TS switch and not on the other side you need to clean the TS connector.
        If you don't get 12v on either ,the problem is in the TS switch,and sometimes you can clean the contacts in the switch and fix the problem.
        Roger
          • 6948
          Ira,
          Rogers test is a good starting place, I would add one more detail, check the connector pins at the base of column, sometimes they'll back out and give you that type of problem. maybe even just turn on that signal and wiggle the wires at the connector. good luck, Ed
          • Ira L.
            • May 31, 2006
            • 32
            Roger,
            Thanks for the detaled directions (pun intended).
            Ira Lippel
            45858
            • Ira L.
              • May 31, 2006
              • 32
              Edward,
              Sounds like an easy starting point.
              Ira
              Ira Lippel
              45858
              • Louis T.
                • July 31, 2003
                • 282
                Hi Ira,
                12/7/08
                https://www.forums.ncrs.org/showthre...65529&uid=3642
                5/26/09
                https://www.forums.ncrs.org/showthre...70024&uid=3829
                Good luck!
                Louis
                • Ira L.
                  • May 31, 2006
                  • 32
                  Hello Louis,
                  I hope all is well with you.
                  Thank you for the two leads. I agree with you, I work much better with pictures and diagrams. I'm going to check out these threads.
                  Ira
                  Ira Lippel
                  45858
