70 Splash Shields? - NCRS Discussion Boards
70 Splash Shields?
  • Ralph B.
    • July 30, 2008
    • 178
    70 Splash Shields?
    How many metal Splash Shields should a 1970 have?
    I know there are (2) small triangular shaped ones (R.H. & L.H. outers) which incorporate a rubber seal stapled on the sides, and I'm aware of the (2) large square ones located under the floor pans.
    A total of (4) shields.
    Am I missing any ????
    Thank you,
    Ralph
    • 3416
    Re: 70 Splash Shields?
    Hi Ralph,
    I can only think of the 4 you mentioned.
    Would you consider the baffle below and behind the core support a splash shield? That would make 5, but that one might not ever be called a 'spash shield'.
    • Dennis D.
      • March 1, 2000
      • 1071
      Hi Ralph,
      Think this is what Alan's referring to.(lower baffle) Don't know how many 70's might still have it, or had it to begin with.
        • 3416
        Hi Dennis,
        Yes, that's it.
        Not too many people remember it, or cars still have it, as you say. There sure are some fancy bends and cuts in it!
        Did it only appear with the metal shroud?
        • Jim T.
          • March 1, 1993
          • 5351
          Ralph my original owner 1970 has only the splash shields you have mentioned. I have air conditioning which has the large radiator, not metal fan shroud like the one Dennis pictured. My 70 has a much larger composite fan shroud. My original owner 68 without air conditioning and smaller radiator has what Dennis has pictured.
          • Dennis D.
            • March 1, 2000
            • 1071
            Alan...
            If I remember without looking,(that might be dangerous), the shroud mounting tabs pass through the lower baffle.
            Jim ....
            I should have mentioned the metal setup appears on the base engine, no A/C, alum radiator. (well at least I haven't heard otherwise). Assume you have a '109 plastic shroud
            • Jim T.
              • March 1, 1993
              • 5351
              Originally posted by Dennis Delpome (33752)
              Alan...
              Jim ....
              I don't recall what numbers are on it, it is a two piece shroud with the lower single piece retained by small bolts.
              • Dennis D.
                • March 1, 2000
                • 1071
                Like this?
                Little too much time on my hands today. Have to get a life
                • Jim T.
                  • March 1, 1993
                  • 5351
                  Dennis when I posted earlier my 70 was parked at work. Just looked at it in the garage and it is the 109 you have pictured. A driven car sure heats up the garage when the door is left down.
