Trans. I.D. - NCRS Discussion Boards
Trans. I.D.
+ More Options
Posts
  • Deane M.
    • January 2, 2007
    • 143
    Trans. I.D.
    Looking for help in identifying a 3 speed manual trans. I have. The numbers are as follows, 3731911 GM, H289 737 450, Q59. The tranny is in perfect condition, I just don't know what its for.
    Thanks for any help.
    Re: Trans. I.D.
    Deane -
    3731911 is the casting number for the side cover for a 1957-1963 cast iron Saginaw 3-speed transmission. Do you have the casting numbers for the main case and tailhousing? Got any photos? Does it look like the photo below?
    • Rod K.
      • 443
      Re: Trans. I.D.
      Tail housing is probably 3737450 (check the "737 450") and the H289 is probably a date code (Aug 28, 1959).
      Check the upper right rear face of the main case for stamped build info.
      • Deane M.
        • January 2, 2007
        • 143
        Re: Trans. I.D.
        Thanks gentleman. I have pm'ed you both and will get back to you later today or in the morning.
        • Deane M.
          • January 2, 2007
          • 143
          Re: Trans. I.D.
          John, hope you got the pictures I sent along with the info.
          • Deane M.
            • January 2, 2007
            • 143
            Re: Trans. I.D.
            Rod, that tail housing cast number is "8737450" not "3737450" as originally thought. Sorry about the misinformation.All other numbers are as reported and are all the numbers on the trans.
