1967 brake rotor clocking - NCRS Discussion Boards
  • Timothy B.
    • April 30, 1983
    • 5202
    To install a brake rotor on a spindle where the rivets are drilled and long gone is it correct to align the adjustment holes for the parking brake and assume this is the correct clocking.
    Still trying to find out when the change occured from first to second design calipers on early 67's..
  • Wayne W.
    • April 30, 1982
    • 3605
    Re: 1967 brake rotor clocking
    There is only one clocking that allows access to the brake adjustment. That is the only correct position, however, nothing says that is the best for run out. It should be, but, if the rotors have been turned or the spindles been changed, all bets are off. They have to be machined together in position to achieve proper run out.
    • Larry M.
      • January 1, 1992
      • 2702
      Agree with Wayne. However, if you removed the rotors from BOTH sides at the same time, you could mix them up and have (additional) run-out problems. The only way to be certain is to install them and then do a run-out check with a dial indicator.
      Larry
