'75 Vette 4 speed transmissions - NCRS Discussion Boards
  • Jim F.
    • July 26, 2010
    • 12
    there is a close ration 4 speed listed as an option for '75 Vette. Is there another 4 speed that ws standard equipment?
  • Martin N.
    • July 30, 2007
    • 594
    Re: '75 Vette 4 speed transmissions
    JIM-
    On a 1975 Vette the M21 is the 4-speed close-ratio trans that was offered on L-82 ONLY. M-20 was the standard 4-speed and M40 was the turbo-hydra-matic auto trans offered as an option.
    Marty
    • Jim F.
      • July 26, 2010
      • 12
      Hi again Marty, did all L82 with 4 speeds have the close ratio or did they also have the M20 in some cases?
      • Martin N.
        • July 30, 2007
        • 594
        As far as I recall, the M-20 was standard on both the L-48 & L-82. The M-21 close ratio was ONLY an option for the L-82 engine.
        Marty
        • Gary R.
          • April 1, 1989
          • 1808
          my 75 L82 came with the WR M-20 & 355's.
          • Jim F.
            • July 26, 2010
            • 12
            Thanks Gary. I'm looking at '75 and don't know if it is close ratio from a distance. I suppose tranny code would tell if I can get it, or try to find tank sticker info. Appreciate you.
            • Martin N.
              • July 30, 2007
              • 594
              I believe that your car should have a Borg-Warner trans in it. Chevy started using them in Corvette's beginning in mid-late 1974. Muncie 4-speeds are used in 1973 & 1974 Vette's. If in fact you do have a B-W 4-speed in your car the production code will be stamped into the main case on the driver's-side flange adjacent to where the tail housing attaches (much easeier than get to the tank sticker, if the sticker is even there). A Muncie trans use's a steel tag attached to one of the side cover bolts with it's production info. on it.
              Marty
              • Gary R.
                • April 1, 1989
                • 1808
                Martin is correct, the ST-10 was used in 75's but carried the M codes used with the earlier Muncies. The 68? started with the VIN stamped in them along with prefix code to denote the ratio. I would have to go back and look this up to confirm the year and coding but you can find it easy enough online.
                If the trans is out of the car the input grooves also will indicate WR or CR.
                The ST-10's have a better 1st gear as well to run lower numerical gears and aid in fuel economy (didn't help all that much)
                Here's the BW ST-10 M20 from my 75. Good luck I like the base 75 coupe a lot, just purchased a very nice original one today in fact.
                • Jim F.
                  • July 26, 2010
                  • 12
                  Thanks--very helpful. Good luck with new car. Jim
