1967 electrical gremlin rear brake and running lights - NCRS Discussion Boards
  • Timothy B.
    • April 30, 1983
    • 5196
    I wanted to pass along a problem I had today with my 67. I just finished the power steering job and after a test drive discovered the rear brake and rear running lights quit working.
    I wanted to pass along the solution to this problem which was the stop light fuse not making good contact to the retaining clip in the fuse box. This stoplight circuit (orange wire) also powers the headlight switch for the rear running lights and dash lights.
    Drove me nuts, the front parking and headlights are powered by another dedicated hot (red) wire in the headlight switch and when pulled for headlights the front parking lights go out. This worked fine, the problem was just in the rear. Also, after cleaning the fuse contact the dash lights seem brighter but that may just be me.
    Sorry for the long rant, I hope this helps someone in the future.
    Re: 1967 electrical gremlin rear brake and running lights
    That's NOT an uncommon issue when we re-use aged original wiring components... Corrosion and surface oxidation between the fuse's metal end cap(s) and the fuse block bayonet holder is often seen to create electrical 'funnies'...
