Rear wheel bearings (71') - NCRS Discussion Boards
  • Michael G.
    • March 2, 2008
    • 485
    I am trying to find the best source for Timken bearings and possibly the actual bearing numbers (Timken reference numbers) for the rear wheel of a 71'.
    Also, in regard to the AC drier/accumuletor. Mine is original and I'd like to know if these need to be replaced or serviced. I'd like to address any weak points before I charge the system. Thanks in advance, Mike
  • Gary R.
    • April 1, 1989
    • 1800
    Re: Rear wheel bearings (71')
    I have the USA bearings if you can't find them. Watch out for imported bearings. You can use them if you like but I only use the USA bearings.
    The bearing numbers on yours are the same for Timken. The originals were NDH bearings,long gone these days.
    • Dick W.
      • 10483
      If the A/C system has been open, you most definitely need to replace the drier. I like to evacuate the system overnight to remove all the moisture, yes I know that the books tell you an hour or so, but 12-18 hours is a lot better.
      Dick Whittington
      • Jim T.
        • March 1, 1993
        • 5351
        Timken bearings are sold by Auto Zone for your 71 Corvette.
        • Michael G.
          • March 2, 2008
          • 485
          Thanks Gary & Dick. Always appreciate your words of wisdom. Mike
