1970 tire tub - NCRS Discussion Boards
1970 tire tub
  • Edward S.
    • February 23, 2009
    • 43
    1970 tire tub
    Just found a very nice tire tub from a 1970 and it has a rockwell products sticker on the side showing from the rear, is this a normal part ? I have a feeling it could be a replacement, or did this come stock with the manufacturers sticker? Thanks Ed
  • Paul O.
    • August 31, 1990
    • 1716
    Re: 1970 tire tub
    Ed the label is found on many tubs and body panels. It should have 2 sets of numbers like 26-70. That would indicate 26th week 1970. Hope that helps.
    Paul 18046
    • Roy V.
      • April 8, 2008
      • 309
      Re: 1970 tire tub
      mine was still attached after 33 years, I should have put some clear protective coating on it, shortly after this picture was taken in 2005 and I started driving the car, the sticker was lost.
      Regards
      Roy
      1972 LT-1 Elkhart Green Coupe
      • Edward S.
        • February 23, 2009
        • 43
        Re: 1970 tire tub
        Great,thank you, the date coincides with the car, good to know it should be there
        • Don L.
          • August 31, 2005
          • 1005
          Re: 1970 tire tub
          Interesting thread. Thanks!
          I took my ('72) tub apart last year to restore it and found the Rockwell decal under the steel frame. Placement was so straight it looked like it was planned that way . Does anyone know for sure that the decal was placed before the tub was riveted to the frame?
          Don Lowe
          NCRS #44382
          Carolinas Chapter
            • 43250
            Re: 1970 tire tub
            Don------
            I'm sure that it was. The labels were applied at the Rockwell plant where the tub was manufactured. I believe the steel support was attached at St. Louis.
              • 3416
              Re: 1970 tire tub
              Hi Edward,
              I believe that that lable is actually part of the molded part and not a 'decal'. For example, you can see it but you can't feel it, or it's edge, with your finger.
              I also found those lables under the front fender panels and on the underbody. The ones I found under the front fenders were high up where there was no black-out or sound deadening. As I cleaned the road grime off, the lables appeared as new.
              • Sal C.
                • December 1, 1984
                • 430
                Re: 1970 tire tub
                I agree with Alan. All of the ones I have seen have been UNDER the surface. But, my lack of ever seeing one ON the surface may just have been explained by the post above.
                • Edward S.
                  • February 23, 2009
                  • 43
                  Re: 1970 tire tub
                  This one is part of the surface of the glass
