Torque for front brake shield - NCRS Discussion Boards
  • Steve L.
    • June 30, 2001
    • 763
    This is the single big upper bolt 11/16-16 x 7/8 that holds the front brake splash shield to steering knuckle casting. It's not in the AIM and I can't find it in the service manuals. This is for a 73
    Steve L
    73 coupe since new
    Capital Corvette Club
    Ottawa, Canada
    • April 30, 1984
    • 158
    Re: Torque for front brake shield
    I just did this last month for the rear disc shields on my '01 1/2 ton PU. I match marked the bolt and shield , then loosened the bolt. I then took my beam torque wrench and noted the amount when the marks lined up as I re torqued the bolt. Should be close enough as it is not a critical part. Hope it helps.-John
    • Steve L.
      • June 30, 2001
      • 763
      I finally did find the number in the archives Jun16 2008 by Joe L.
      Steve L
      73 coupe since new
      Ottawa, Canada
      • Scott S.
        • September 11, 2009
        • 1961
        Steve, do you happen to recall where this information is located, or what search terms you used to find it? I have searched Joe's name and "Torque", then searched Joe's name with no subject, bringing up all 25,000+ posts, then isolated June 16, 2008 and read all of his posts on that day, and I haven't found anything about the torque rating for this bolt (GM 3864119) yet.
          • 3422
          Hi Scott,
          70 ft/lbs.
          Here's the link to another thread.
          I remembered this one.
          I need to get a real life.
          https://www.forums.ncrs.org/showthre...80495&uid=3381
          • Scott S.
            • 1961
            Hi Scott,
            70 ft/lbs.
            Thanks Alan!
            I see now that it was hiding in an August 24-25th 2010 thread
