Does anyone out there have advise on replacing the driver side door spring without removing the door?  The spring on mine will hold the door open, wide open, but on a slight incline the mid-open position is a little sloppy.  Thanks.
					1972 door spring replacement
 Re: 1972 door spring replacement
 Corvette magazine has some good instructions posted online and this is one that applies:
 The tool that is offered by most vendors makes the job a lot easier and looks like it can be made at home rather easily. I went ahead and bought one after I spend a whole lot of time trying to insall with a regular screwdriver.
 Here is what it looks like:
 Good luck this is a rather easy job and will possibly save damage to the door skin from opening too far.- Top
 Kurt, as others have said the tool makes replacement much easier. I painted mine body color before installing it. Also I wraped the tool and all places the tool could possibly contact in double thickness of duck tape. No scratches or chips and you can't tell it's been replaced. The original actually broke in half necessitating replacement.
 LarryLarry
 2002 Z51 Convertible
 1969 L46 Convertible- Top
