1972 door spring replacement - NCRS Discussion Boards
  • Kurt G.
    • April 30, 2005
    • 343
    Does anyone out there have advise on replacing the driver side door spring without removing the door? The spring on mine will hold the door open, wide open, but on a slight incline the mid-open position is a little sloppy. Thanks.
    Kurt Geis
    Chairman, Midway USA Chapter
    Targa Blue 1972, Top Flight and Duntov Award, 2014
    Arctic White 1994, Top Flight, Hrt. of Amer. Reg. 2011
    Arctic White 2013 60th Anniv Special Edition Conv.
    • 15632
    Re: 1972 door spring replacement
    I am told it can be done, and have seen photos in a long ago Vette Vues, but I thankfully have no personal experience.
    • Harmon C.
      • August 31, 1994
      • 3228
      With a special tool sold by vendors it can be done. It's not easy on the first one you install. After the learning curve it's a five minute job.
      Lyle
      • Bob D.
        NCRS Shipping Data Report Manager
        • April 30, 1996
        • 795
        Kurt
        I have instructions from a vendor on how to replace the spring. I'll make a copy and ship it to you. I'll check to see if I can scan it also and email to you.
        • Anthony M.
          • September 30, 2001
          • 58
          Corvette magazine has some good instructions posted online and this is one that applies:
          The tool that is offered by most vendors makes the job a lot easier and looks like it can be made at home rather easily. I went ahead and bought one after I spend a whole lot of time trying to insall with a regular screwdriver.
          Here is what it looks like:
          Good luck this is a rather easy job and will possibly save damage to the door skin from opening too far.
          • Paul Y.
            • September 30, 1982
            • 570
            When positioned properly, it actually slips in surprisingly easy.
            It's a good life!
            • Jim D.
              • 2885
              I've done several of them. With the correct tool (large bent screwdriver) it takes only a few minutes to install one.
              • Lawrence M.
                • February 1, 1995
                • 404
                Kurt, as others have said the tool makes replacement much easier. I painted mine body color before installing it. Also I wraped the tool and all places the tool could possibly contact in double thickness of duck tape. No scratches or chips and you can't tell it's been replaced. The original actually broke in half necessitating replacement.
                Larry
                Larry
                2002 Z51 Convertible
                1969 L46 Convertible
                • Robert S.
                  • May 31, 1988
                  • 81
                  I have done this once. Seemed really easy at the time. Used a drum brake adjustment tool and it was obvious what needed to be done.
