67 3x2 #3660 correct choke pull-off - NCRS Discussion Boards
  • Dereck S.
    • July 30, 2008
    • 244
    Looking for guidance on which choke pull-off is correct a straight pipe or curved pipe? Application is the center carb #3660 on a 3x2 tripower.
    thanks,
    Dereck
  • Michael J.
    • January 27, 2009
    • 7122
    Re: 67 3x2 #3660 correct choke pull-off
    Do you mean the linkage that goes from the choke lever to the heat sink in the manifold?
    • Dereck S.
      • July 30, 2008
      • 244
      Hi Mike,
      Sorry, I meant the vacuum actuated choke pull-off which pulls the choke open approximately 1/2" after engine start to prevent flooding. It's on the right side and is approximately 1" in diameter with a curved link/arm attached. I currently have one with a curved pipe that the vacuum hose attaches to. I've seen straight and curved on cars. I suspect one is replacement but I'm not sure.
      Dereck
      • Wayne M.
        • March 1, 1980
        • 6414
        All nozzles I've ever seen [choke vacuum break] are curved; the service units are straight, IMO.
        • Dereck S.
          • July 30, 2008
          • 244
          Thanks Wayne, I suspected the straight pipe was a replacement design.
          • Michael J.
            • January 27, 2009
            • 7122
            Originally posted by Dereck Schlett (49285)
            Hi Mike,
            Dereck
            Mine is curved too.
