Leaking carb inlet - need gasket - NCRS Discussion Boards
  • Art B.
    • 333
    My '61 1x4 carb was leaking gas at the inlet where the bronze filter is located. The fitting is a 1" hex. I cannot find the gasket (looks like paper) anywhere in Corvette Central or Paragon. I suppose I could try to make one. Anyone know of a vendor who has it?
  • Clem Z.
    • January 1, 2006
    • 9427
    Re: Leaking carb inlet - need gasket
    holley gaskets are soft aluminum colored black. go to a local speed shop to get the correct gasket.
      • 43273
      clem------
      Will a Holley gasket fit a WCFB?
        • 43273
        Art------
        The original gasket was GM #3764576, aka Carter #121-319.
        • Clem Z.
          • January 1, 2006
          • 9427
          clem------
          when you said a bronze filter i assumed it was a holley
          • Art B.
            • 333
            Joe: Thanks for the numbers. I also thought of using some thread sealer on the fitting. It worked for an antifreeze leak I had on the intake manifold of my '57. The fuel leak on the '61 could have been a disaster. Fortunately I discovered it while in my driveway.
            • Clem Z.
              • January 1, 2006
              • 9427
              what is outside diameter of the fittings thread and if it is 7/8" a holley gasket will fit.
                • 6955
                Art, my two cent on the thread sealant, if a piece does make its way into the needle and seat - you will have a problem, like flooding, not good, the factory or replacement gasket is all you need. Ed
                • Art B.
                  • 333
                  Clem: You are correct. It is 7/8".
                  • Clem Z.
                    • January 1, 2006
                    • 9427
                    then a holley gasket will work if you can't find a original type.
