Gasket between Hose and Fuelpump on C1? - NCRS Discussion Boards
  • Jorn J.
    • October 21, 2008
    • 142
    Hi
    I have this little problem that Gas is "dripping" from the 45 degree Flex Gas line Fitting/flex Gas Line where they are connectet before the Fuel Pump and I have tryed to put on such "tape" but it's only good for one day. Should the Hose and fitting mounted together without any form for Gasket?
    Regards Jorn/Denmark
  • Terry D.
    • May 31, 1987
    • 2698
    Re: Gasket between Hose and Fuelpump on C1?
    Jorn
    You are correct, they just screw together. It sounds like the end has a nick in it, or the seat is bad. They are not that exspensive, I would just buy new ones. If you are set on using what you have, go to a store that handles Loc-Tite products. They make a sealer that will solve your problem, don't remember the number and I'm on vacation so I can't go to thegarage and look.
    • Jorn J.
      • October 21, 2008
      • 142
      Hi Terry
      The Hose and Fitting are new so I will try to just tighten them hard together.Thanks for answering and have a good vacation
      regards Jorn
      • Gary C.
        Administrator
        • October 1, 1982
        • 17947
        Jorn, try some aircraft/aviation type sealant such as "fuel lube". Here's a U.S. product. Gary....
        NCRS Texas Chapter
        https://www.ncrstexas.org/
        • Richard M.
          Super Moderator
          • August 31, 1988
          • 11365
          Jorn, These are brass pipe thread fittings. I have learned over the years to "Not" use teflon tape on them. It is not recommended. It can allow too much "slip", reducing friction and can cause a crack in the fitting if overtightened, especially if into aluminum castings.
          By design, pipe thread fittings typically do not need a sealer. Tighten them up and you should be ok. If you must, you can use a product like Gary shows, or just good old fashioned pipe thread compound typically used for natural gas pipe. I use that and it always seems to work for older fittings I reuse. I use the sealant is insurance.
          Rich
