Re: C1 spindle direction
Can't get a good measurement of the inside faces all assembled. .....
I measured apx 3.150" using a caliper on the outside faces of the arms.
Also, the torque spec for the locknut is as I recall(not at my ST-12), "100-150 lbs/ft". You may have a issue where when you torqued the nut it may have damaged the captive nut threads. Or maybe it was like that before.
(edit: I reread your post and misunderstood the "1 thread" part. As long as the captive nut threads are ok ignore this part)
