C5 lights fail to go up. - NCRS Discussion Boards
+ More Options
Posts
  • Joseph K.
    • August 26, 2008
    • 407
    Last night I went to go home and the headlights failed to go up and turn on. After turning the switch on and off several times they finally went up and turned on.
    Anyone run into this problem? Thanks Joe
  • Clem Z.
    • January 1, 2006
    • 9427
    Re: C5 lights fail to go up.
    there is a relay for those lights that could be going bad. go over to www.corvettemechanic.com for a better answer
      • 6948
      Joe, thats one of those electrical problems that we mechanics do not like to see. (Erattic operation) If it were me like clem says try a relay. its certainly cheal enough, or you maybe able to swap the relay with another with the same part no. like maybe the wipers or something that doesn't get used much.
      • Joseph K.
        • August 26, 2008
        • 407
        So you think the relay may be in the pod with the others under the hood. I give it a try.
          • 6948
          Joe, I looked up whats tied into the headlamp doors not opening, there is a circuit breaker #54 In the I/P fuse panel, and there is a H/lamp opening relay #44 in the I/P. there is also a control module, but try to get the headlamp doors not to work and wiggle the circuit breaker and tap the relay and see what happens first.
          Let me know if you can see the headlamps, are they lite with the switch on?
