C1 1957 park light housing - NCRS Discussion Boards
  • Dan P.
    • December 1, 1990
    • 683
    Does anyone know what finish is on the park light housings cad, yellow cad ,painted black??????
  • Richard M.
    Super Moderator
    • August 31, 1988
    • 11323
    Re: C1 1957 park light housing
    Dan, I have a nos set that are painted black.
    • Dan P.
      • December 1, 1990
      • 683
      that is what i thought thanks . were the wires wraped with cloth tape at the housing then plastic tubing
      • Roy B.
        • February 1, 1975
        • 7044
        Black may have been a over the counter but yellow cad was original
        That's my 2 cents
        • Roy B.
          • February 1, 1975
          • 7044
          For 57 no cloth and and tubing was rubber
          • Richard M.
            Super Moderator
            • August 31, 1988
            • 11323
            These of mine must be over the counter service replacements then. Obviously they didn't come with the wiring. I would imagine that as Roy explains originals were likely yellow cad.
            However, I wonder if it really matters. In the wheelhouse blackout process wouldn't they get painted, then have undercoating applied?
            Rich
              Rich
              Rich -
              Nope - the undercoat and wheelhouse blackout operations were done in the Paint Shop after the Final Bake oven, long before the parking lights were installed on the Hard Trim Line.
              • Ron B.
                Infrequent User
                • July 31, 1976
                • 20
                Dan
                I purchased new lights for my 57 in 1968 from the Chev dealer where I worked. New in the box, they were cad plated. Later had --( some )undercoating after installed.
                Ron B
                Same 57 since 1968
                • Richard M.
                  Super Moderator
                  • August 31, 1988
                  • 11323
                  Rich -
                  Thanks for the explanation John.
                  So by comparison, later years, like my 59, undercoating was applied after the headlight buckets were installed right? Mine had undercoating on the buckets.
                  Same for the 57? .....undercoating on the buckets?
                  Rich
                    Rich
                    Rich -
                    Not sure. I have some old St. Louis Paint Shop process notes that indicate two different processes starting in '58; one says tape was applied over the top fender molding holes prior to undercoat to keep it from blowing through the molding holes, and the other one says the application was moved to after the top molding was installed (or the molding was installed in the Paint Shop prior to undercoating).
                    Examining a known-original/untouched car would help answer those questions.
                    • Adam S.
                      • July 30, 2008
                      • 167
                      Hi, my 1957 23hundred serial # had cad plated (gray ox-a-dized looking from age) housings with what was left of rubber tubing.....no signs of undercoat
                      • Bill H.
                        Infrequent User
                        • February 1, 1982
                        • 19
                        I have attached pics of NOS set ( still in black/yellow Delco box). They are dichromate (yellow colored CAD -- is that the right term?). Wiring harness sheath is rubber. I have had these since about 1981. Hope this helps. (I am struggling with getting these uploaded --if they did not attach I'll try again later).
                        Bill
                        • Michael A.
                          • June 30, 1986
                          • 68
                          Hi Guy's
                          I agree with John Hinckley and the other replies regarding the zinc chromate coating and rubber wire housing. My NOS lights purchased in the late 60's to be installed in 56 no. 10 are finished as described. Also the originals which came out of the car were never coated with undercoating. Hope this helps Dan.
                          Later Mike (317)729-2418
