RE: 1968 Corvette UA6 ALARM OPTION - NCRS Discussion Boards
  • Jerry B.
    • August 31, 1994
    • 416
    Hello Folk, Looking For A Owner That Has A 68 With An Anti-theft System. I Have Several Questions. Thanks
  • Jack H.
    • April 1, 1990
    • 9906
    Re: 1968 Corvette UA6 ALARM OPTION
    Why not just ask your question(s)? Some have owned such and now no longer own them. Others judge frequently and have seen these critters...
    • Jerry B.
      • August 31, 1994
      • 416
      Hello Jack, I Am Working On Very Early 69 With A Ua6 Option. I Posted An Earlier Thread Discussing This Option. Is The E69 The Same Layout As A 68? ( Withseparate Jam Switches) It Was Suggested That My Alarm System Was Wired In Conjuction With The Courtsey Door Jam Switchs. My System Has Three Separate Switches, Two Door Jam Switches And A Hood Switch. The Horn Works When The Key Is Activated And The Switches Do Not Seem To Have Any Effect On The Operation. On A Previous Thread Someone Sent Me A Wiring Diagram For Alarm System But Does Pertain To My System. Hopefully I Have Not Totally Confused Everbody. Any Help Wpould Really Be Appreciated.
        • 15600
        Well you are working hard at confusing me, but I am easily confused.
        BTW: How do you get the first letter of each word capitalized? I sometimes want to do that, and I haven't yet found a way unless -- I use Word Perfect.
        • Jerry B.
          • August 31, 1994
          • 416
          Hello Terry Simply, Is There A Difference Between And A 68/72 Ua6 System.
            • 15600
            Yes. There were several changes in the UA6 system over the years. Some in the door pin switches, and another in the location of the relays and flasher in the passenger side storage compartment. I don't think the change in location of the relays and flasher would change the wiring diagram as they were only moved several inches.
            • Roger O.
              • September 7, 2009
              • 209
              As I remember it the early C3s used the jamb/courtesy switch to trigger the alarm.
              Later years around 72 the door ajar switch was used to trigger the alarm.
              The alarm trigger wires should be white/black tracer , pull your ajar switch to check wire color but I'm betting your car use's the jamb switches.
              If the alarm horn blows when you turn the key on then the white/black is most likely going to ground triggering the alarm BUT the alarm horn could have been mounted wrong and is grounded all the time OR the wiring has been modified.
              This system is actually very simple but can be very confusing because of the tricky wiring. Unlike a normal horn the spade on the horn is made hot as soon as you turn the key on , grounding the horn case makes the alarm sound.
              • Jerry B.
                • August 31, 1994
                • 416
                Thanks Folks For All Your Replies. Roger , I Am Out Of Town, When I Return, I Will Check The Grounds.
                • Roger O.
                  • September 7, 2009
                  • 209
                  Your welcome , if you don't find the problem let me know and I can walk you through ways to isolate the problem.
