C1 Old Crappy Frame NEEDED - NCRS Discussion Boards
  • Justin B.
    • March 1, 1996
    • 478
    The body shop restoring my 1958 needs a frame to mount my body on as they do their work. Does anyone have an old rusty one or a not so useable frame that you would sell for cheap or a frame that you would even consider renting? I am in the Charlotte N.C. area and would consider traveling 300-400 miles. Thanks!!
  • Terry D.
    • May 31, 1987
    • 2698
    Re: C1 Old Crappy Frame NEEDED
    If you search the archives I believe you will find articles on building a frame out of wood, much cheaper and no need to travel anywhere but your local lumber yard.
    • Justin B.
      • March 1, 1996
      • 478
      I have it on a nice rolling dolly already but he (the body man) wants it for more accurate door alignment and so on.
      • Dan H.
        • July 31, 1977
        • 1372
        The only good fit will be your original frame with its shims for your body. Anything else will be a crap shoot. Why not use your frame wrapped in plastic etc. for a set up tool?
        Dan
        1964 Red FI Coupe, DUNTOV '09
        • Justin B.
          • March 1, 1996
          • 478
          I already have the complete rolling chassis and drivetrain complete, Its a big brake fuelie and I don't really want this thing out of my possession.
          • Paul J.
            • September 9, 2008
            • 2091
            Dan
            Justin, all frames are not the same. Dan's idea is good.
            • Richard M.
              Super Moderator
              • August 31, 1988
              • 11367
              Justin, I would have to agree that the best solution is your own frame. I just completed a frame restoration of a 59 and had the body on a dolly. For accuracy, the body is now back on the frame to complete bodywork etc.
              However, if you really think you want to use another frame for your setup, I have a unhit original '62 frame sitting around doing nothing and you are welcome to make arrangements to use it for as long as needed. You could just give me a deposit and when you return it to me we swap back. The front crossmember is off and needs 2 front wheels/tires but this could be bolted up easily and you supply the wheels/tires yourself.
              However I am beyond your limit of travel.......maybe. According to googlemaps I'm about 580 miles from Charlotte here in eastern Florida, about 2 hours south of Daytona. Your other option is to use a transporter. I may know someone who hauls between FL & Delaware often and may be in the area.
              PM if you're interested.
              • Ridge K.
                • May 31, 2006
                • 1018
                Justin, I would be the first to help you if I had the frame you need.
                Having said that, keep in mind that thousands of vintage Corvettes have been restored with bodies on frame dollies.
                I must agree with the others who have given you excellent advice. I two, believe that all frames are in fact....slightly different.
                Ridge.
