I know that the ZN232 Signal Stat flasher (GM # 3713382 in Gr. 2.892) was used in 1955-1960 Corvettes as I have had a few over the last 30 years. I have a NOS CP232 Signal Stat flasher that lookes identical to the ZN232 flasher EXCEPT that it has 3 prongs. It is stamped "M387M" (38th week of 1957 or 1967???) on the side. Does anyone know the application for the CP232 Signal Stat flasher?
55-60 ZN232 Signal Stat Flasher
Re: 55-60 ZN232 Signal Stat Flasher
Mine is round 55 and the bracket design is for holding a round flasherI know that the ZN232 Signal Stat flasher (GM # 3713382 in Gr. 2.892) was used in 1955-1960 Corvettes as I have had a few over the last 30 years. I have a NOS CP232 Signal Stat flasher that lookes identical to the ZN232 flasher EXCEPT that it has 3 prongs. It is stamped "M387M" (38th week of 1957 or 1967???) on the side. Does anyone know the application for the CP232 Signal Stat flasher?
Roy - Unless the turn signal flasher clip on your car is different than the clip used newer Corvettes in the later 50s thru the 70, the clip is designed to hold both configurations, i.e. rectangular and round, of turn signal flashers. Show us your turn signal flasher clip.
Pete
