55-60 ZN232 Signal Stat Flasher - NCRS Discussion Boards
  • David L.
    • July 31, 1980
    • 3310
    I know that the ZN232 Signal Stat flasher (GM # 3713382 in Gr. 2.892) was used in 1955-1960 Corvettes as I have had a few over the last 30 years. I have a NOS CP232 Signal Stat flasher that lookes identical to the ZN232 flasher EXCEPT that it has 3 prongs. It is stamped "M387M" (38th week of 1957 or 1967???) on the side. Does anyone know the application for the CP232 Signal Stat flasher?
  • Roy B.
    • February 1, 1975
    • 7044
    Re: 55-60 ZN232 Signal Stat Flasher
    Mine is round 55 and the bracket design is for holding a round flasher
    • Peter L.
      • May 31, 1983
      • 1930
      Roy - Unless the turn signal flasher clip on your car is different than the clip used newer Corvettes in the later 50s thru the 70, the clip is designed to hold both configurations, i.e. rectangular and round, of turn signal flashers. Show us your turn signal flasher clip. Pete
      • Roy B.
        • February 1, 1975
        • 7044
        I dont have the time right now just got the engine back to gather . But it's a U shape that a screw hold it to the under dash lip.
