Loose Mirror Base - NCRS Discussion Boards
Loose Mirror Base
  • Jeff P.
    • 799
    Loose Mirror Base
    Morning Guys,
    The outside mirror is loose at the base on my 68 . I searched for a while but the threads are usually on the ball part. I tightened up the nut (gently) but the base still wobbles. Any help is greatly appreciated. Jeff
    68 L79 Convertible: Triple Black: Work In Progress, Body off. Now on!
    2014 Arctic White Z51 Vert. (Wifes)
  • Jack P.
    • March 19, 2009
    • 1135
    Re: Loose Mirror Base
    Originally posted by Jeff Pollard (15573)
    Morning Guys,
    My 66 did the same. Simple fix. Take off and put a little more gasket (Thicker) make your own if need, under base. The mirror shakes because you can't tighten it down any more then the thin gasket (old) that helps the base stand off of body.
    Once you have a little more stand off, the hex nut can be tighten and will keep mirror steady.
    Jack
    • Jeff P.
      • 799
      Thanks much Jack, new prodject.
