63 Park Brake Idler Lever - NCRS Discussion Boards
  • Jon R.
    • February 8, 2010
    • 163
    Re: 63 Park Brake Idler Lever
    And here is a mid-December that I snagged from Ebay - looks bent to me!
    • Jack Y.
      • June 30, 2005
      • 76
      Mine had a bend and the gouge in the fiberglass led me to believe it was not intentional. I straightened it....
      • Jon R.
        • February 8, 2010
        • 163
        #18
        Jack,
        Do you have a picture you could post?
        Jon
        • Jack Y.
          • June 30, 2005
          • 76
          #19
          Sorry, I tried but I couldn't get a clear image. The fiberglass had a clear semi-circle from the end of the spring digging into it. I was trying to make the e brake work more smoothly and I figured that friction was not helping things.
          • Jon R.
            • February 8, 2010
            • 163
            #20
            Jack,
            Is/was the bracket bent also or just the lever?
            Jon
            • Jack Y.
              • June 30, 2005
              • 76
              #21
              The bracket is/was straight and the lever was bent upward. BTW, it is a very early Feb, car.
              • Sydney G.
                • February 1, 1994
                • 444
                #22
                Jon and Bob,
                I checked my coupe tonight and my bracket also has a slight bend upward as your picture shows.
                Syd
                  • 15680
                  #23
                  The last change is "6", so it appears as if the change record got filled up with "5" and was replaced with a new one, so the previous changes got lost.
                  My 3/63 built SWC is straight.
                  Maybe you are on to something.
