undercoating removal - NCRS Discussion Boards
  • George L.
    Infrequent User
    • July 31, 2003
    • 6
    I am removing the undercoating from under car. How do I know what was undercoated at the factory. how much undercoating was applied to the car and where? Under the fenders is where I am most unsure of. Also the rubber splash shields by the control arms. Thanks for any help you can provide.
    George Laishley
  • Edward J.
    • September 15, 2008
    • 6961
    Re: undercoating removal
    George, the factory didn,t undercoat much on the car, I think the areas were, behind each wheel well , the seat belt re-inforcement plates above the rear wheels. ( the undercoating from the factory was very thick when applied). The rubber a/arm covers didn't have any coating.
    I think if you go to Patrick H.profile he has a website with many photos of his 72 bowtie car.
      • 3422
      Hi George,
      I believe that often when the seat belt reinforcement that Edward mentioned was coated a bit of the spray ended up on the side of the battery compartment and also on the side of the jack compartment. Just a little!
      • Steve L.
        • June 30, 2001
        • 763
        George,
        Why do you want to remove the orignal undercoating that came out of the factory?
        Steve L
        73 coupe since new
        Capital Corvette Club
        Ottawa, Canada
        • George L.
          Infrequent User
          • July 31, 2003
          • 6
          My car was undercoated by the dealer. I am trying to remove only what the dealer installed and have the factory undercoating remain. I am unshore if the black out installed in the fender wells is close to the same as undercoating. I dont want to remove too much and find I have done more than was necessary.
          thanks George
          • Steve L.
            • June 30, 2001
            • 763
            On my 73, the factory undercoating in the rear wheel wells went up to and including the zinc shoulder belt reinforcement plate and a few inches towards the rear. If this helps you.
            Steve L
            73 coupe since new
            Ottawa, Canada
