T-3 headlights - NCRS Discussion Boards
T-3 headlights
  • Dale S.
    • November 12, 2007
    • 1224
    T-3 headlights
    I read an article about sealing original T-3 headlights against escaping gas causing them to burn out. The solution as I remeber it was to paint around the headlight brass connectors where they meet the glass with clear nail polish. I looked in the Archives and could not find it. Does anyone remember this articile? Maybe it was on another board. Thank you Dale
  • Jim D.
    • 2885
    Re: T-3 headlights
    I asked the same question a while back. The consensus then was to use a silicone sealer around the base of the terminals on top of the original sealer.
    Jim
    • Dale S.
      • November 12, 2007
      • 1224
      Re: T-3 headlights
      Thank you Jim, glad I was not dreaming it. Will try Dale
      • Pat M.
        • April 1, 2006
        • 1588
        Re: T-3 headlights
        I like using epoxy, it's more durable and less prone to being peeled off.
        • Roy B.
          • February 1, 1975
          • 7044
          Re: T-3 headlights
          How would anyone know if it hasn't already escaped
          • William L.
            • December 1, 1988
            • 944
            Re: T-3 headlights
            I don't think it will hurt to seal it, but how can ya prove that sealing it worked?I think it's just an old car guy's tail!!!!
            Bill Lacy
            1998 Indy Pacecar
            • Pat M.
              • April 1, 2006
              • 1588
              Re: T-3 headlights
              If the headlight works, the seal has not been broken and the gas hasn't escaped. And, as Bill says, it can't hurt to re-seal it.
              • Jim D.
                • 2885
                Re: T-3 headlights
                It's very common for the original sealer to get old and fail, causing the bulb to lose its vacuum and burn out the filament. Adding a sealer helps prevent this from happening, or at least, that's the experts opinion. I still have the original date coded T-3's in my 65 and they work fine so I added a sealer. What can it hurt?
                • Dale S.
                  • November 12, 2007
                  • 1224
                  Re: T-3 headlights
                  I'm with you Jim, What can it hurt? D/
