cure for hard hot start - NCRS Discussion Boards
  • William F.
    • June 9, 2009
    • 1363
    Thought I'd share this with you in hope it helps. Had lots of suggestions about my hard hot starting problem on my '67 L-79:flooding, too much advance, bad gas,etc., but was none of above was the problem. With lots of free help by phone from Chuck Hawk( Chuck Hawk's Auto and Performance, Tuscon, AZ.(520)292-0880, and some from Pertronix, decided wasn't getting enough spark to ignite mixture when cranking hot. Sure enough, only 4 V on hot side of coil on cranking. Traced problem to a bad solenoid. With new solenoid get 12V when you turn key and starts right up.
  • Larry M.
    • January 1, 1992
    • 2695
    Re: cure for hard hot start
    Bill:
    Very interesting. This is an often overlooked, but critical area. Not certain if the Pertronix system makes this worse than with points......but 4 volts to the coil is definitely too low.
    Thanks for sharing. I'm sure it will help others.
    Larry
    • Clem Z.
      • January 1, 2006
      • 9427
      that is why GM came out with heat shields for the solenoids. also after years of use the contactor inside the solenoid get burned and need cleaned up
      • Bill M.
        • 1328
        My 67 l 79 does the oposite hard to start when cold always have to give a shot of starting fluid.
        • Clem Z.
          • January 1, 2006
          • 9427
          make sure the choke plate is completely closed and check to see if you a pump shot when you first try and start it.
