Thought I'd share this with you in hope it helps. Had lots of suggestions about my hard hot starting problem on my '67 L-79:flooding, too much advance, bad gas,etc., but was none of above was the problem. With lots of free help by phone from Chuck Hawk( Chuck Hawk's Auto and Performance, Tuscon, AZ.(520)292-0880, and some from Pertronix, decided wasn't getting enough spark to ignite mixture when cranking hot. Sure enough, only 4 V on hot side of coil on cranking. Traced problem to a bad solenoid. With new solenoid get 12V when you turn key and starts right up.
cure for hard hot start
Tags: None
Re: cure for hard hot start
Very interesting. This is an often overlooked, but critical area. Not certain if the Pertronix system makes this worse than with points......but 4 volts to the coil is definitely too low.
Thanks for sharing. I'm sure it will help others.
Larry- Top
