'57 Fiberglass transmission cover - NCRS Discussion Boards
  • Garry E.
    • September 30, 2002
    • 240
    Does anyone know why the fiberglass cover over the transmission "hump" inside the car (under the carpet...) is held down with phillips-head screws and glued to the floor pan...? I can understand the screws - remove them and you could have easy access to the shift linkage and top of the transmission...... But my cover is tighly glued to the floor and screwed down!!!! I don't want to break the original glued panel loose from the floor, but this whole matter doesn't make sense....
    Anyone with thoughts on this.....?
    Garry Eastwood
    #38705
  • Mike M.
    • May 31, 1974
    • 8391
    Re: '57 Fiberglass transmission cover
    both my 57 floorpans are as you describe. would'a been nice if they hadn't bonded the panel to the floor pan. mike
    • Scott S.
      • March 1, 1979
      • 747
      Both 1956 serial 2765 and 3218 are screwed but only a sealant was used.
      Scott
      • Gary C.
        Administrator
        • October 1, 1982
        • 17704
        Garry, same reason the inner fenders have screws. To hold in place until the sealant/resin sets up. JMTCW, Gary....
        NCRS Texas Chapter
        https://www.ncrstexas.org/
        • Tom P.
          • April 1, 1980
          • 1815
          The tranny cover on my 56 (4363) is the same (screwed and glued). This is a VERY LATE (last week of production) 56 car.
          • Dan D.
            • November 5, 2008
            • 1323
            Found the same thing on my 57 last year. Wanted very badly to remove it, but gave up - not wanting to damage it. I agree with all the comments posted. -Dan-
            • Garry E.
              • 240
              GC - thanks for explaining the General's logic on this...... this quetion dovetails the "screws-in-the-inner-fender" question I asked you in G'Burg recently....
              Garry
