C2 center console with A31 - NCRS Discussion Boards
+ More Options
Posts
  • R N.
    • May 31, 2002
    • 640
    Hello Everyone,
    Where there two different center consoles for the C2's with A31 power window option - one for power windows and one without, or was there a knock out on the console for fitting the power window switch?
  • Bob R.
    • June 30, 2002
    • 1595
    Re: C2 center console with A31
    I can't speak for all C2's but in 63 there were different consoles. The power winonsole had an opening for the switches and the non power had nothing at the switch location.
    • Harry L.
      • January 1, 1980
      • 96
      I have found that all C2's had different consoles, determined by with or without Power Windows.
      Harry Ledgerwood
      Member #2901
      Current Region VII Director (2021 thru 2023)
        Originally posted by R. Kurt Neiman (38038)
        Hello Everyone,
        Kurt -
        At St. Louis, there were 32 different part numbers of consoles (with and without power windows and/or manual vs. Powerglide, times interior colors), which were painted by the supplier. The A31 raw casting was unique at the supplier level due to the switch opening and the switch attaching bosses.
          • May 31, 1974
          • 8400
          on the 64-67 consoles, if you turn the console over , you'll see a rectangular depression in the underside of the console. it can be removed and a PW switch mounted on a console out of a non-PW 64-7 vette. mike
