Coil Bracket Bolts -Original? - NCRS Discussion Boards
  • Larry T.
    • May 15, 2007
    • 404
    Are these coil bracket bolts and capacitor bracket screw original? They look a little shiny because the last owner of the parts sprayed them with some sort of clear finish. Also, what vintage would these parts be correct for?
    Thanks.
    • 43248
    Re: Coil Bracket Bolts -Original?
    Thanks.
    Larry------
    Those we among the ones that were used, so I would not doubt that they're not only correct but also original to the car.
    The bracket mounting bolts with the 3 radial lines at 90 degrees to each other designate a GM 275M material grade fastener. Why they used these in several locations on the car, including the coil bracket mounting, I do not know. GM 275M is a material grade just below GM 280M which is equivalent to SAE grade 5. The 280M fasteners are VERY common on Corvettes.
    • Rich P.
      • January 12, 2009
      • 1361
      Larry,
      If you are looking for BB coil bolts the Anchor over TEE bolts are what I see in 68-up. 65-67 for typicaly have a flanged head. I can post some pics if you want.
      Rich
      • Rich P.
        • January 12, 2009
        • 1361
        Larry,
        here is what I would expect to see for a 66 BB.
        Rich
        • Larry T.
          • May 15, 2007
          • 404
          Rich,
          Thanks for the picture. Attached are pictures of what are on my 66. Look a lot like yours with a different head marking. The first ones came with a coil bracket I picked up. I did not know if mine were correct or if the ones without the flange would have been.
          Larry
          • Rich P.
            • January 12, 2009
            • 1361
            Larry,
            yep those are correct.
            Rich
