Battery Disconnect Switch - NCRS Discussion Boards
  • Bob A.
    • April 1, 2003
    • 172
    Please advise! Is it a good idea to use a Battery Disconnect Switch? If so, what is a good make and style? Is it necessary to alter/modify the Battery Cable when using one of these Switches?
    Bob Adams
  • William L.
    • December 1, 1988
    • 944
    Re: Battery Disconnect Switch
    Bob Adams
    Bob
    I feel that it is extremely important to use a battery switch. I like the knife style switch over the screw style but both will work on C1 & C2's You do not have to modify your battery cable.
    Bill Lacy
    1998 Indy Pacecar
    • Paul L.
      • November 1, 2002
      • 1414
      I have always used them. I prefer the knife (guillotine) style. Very sturdy. No mods necessary. The pic shows my 1974 setup. Don't be distracted by the extra wiring; that is a fused circuit for a rear Blaupunkt subwoofer.
      • James R.
        • September 30, 2005
        • 93
        Originally posted by William Lacy (14279)
        Bob
        I agree. I also use a knife style on my 65.
        • Michael M.
          • February 1, 1993
          • 604
          It's definitely a battery saver which ever style you use. Plus with a NCRS decal and a fire extinguisher you get some extra points in judging.
          • Joe R.
            • May 31, 2006
            • 1822
            Bob Adams
            Bob,
            It's real handy if (heaven forbid) your car ever has an electrical fire.
            Joe
            • Lawrence R.
              • March 23, 2010
              • 56
              The battery switch sounds like a great idea, but what good is the alarm system on the car with the battery dis-connected other than someone not being able to start it to steal the car.
              • Joseph K.
                • August 26, 2008
                • 407
                Old cars with old wiring lead to unfavorable conditions that may lead to fires. It is best to have a battery disconnect then not. As far as a security alarm, it is the choice between two evils... fire/melted car or a missing car. I have had the knob type of disconnect for two years with out a problem.
                • John F.
                  • March 23, 2008
                  • 2415
                  Who sells a good knife disconnect?
                  John F
                  • Paul L.
                    • November 1, 2002
                    • 1414
                    John F
                    Wirth at JC Whitney. Solid unit
                    • Lawrence R.
                      • March 23, 2010
                      • 56
                      I am sold on the switch, but what about your clock? do you reset it everytime you cut off the battery? or can you add something to keep the clock going?
                        • 3416
                        Hi Lawrence,
                        I use a disconnect and reset the clock each time on my 71. It takes just a moment while I'm waiting for the engine to warm up.
                        • Lawrence R.
                          • March 23, 2010
                          • 56
                          Hi Lawrence,
                          Hi Alan,
                          I had a clock in my 73 and when I went to set the time the gear came off the shaft that reset the time. I bought a new clock and don't want to reset no more than I need to the clocks are expensive. Thanks for the input.
