1970 open air cleaner base - NCRS Discussion Boards
  • D S.
    • March 1, 2005
    • 1551
    Can someone please post photos of both sides of the original open air element air cleaner base? Were there any differences between the small block and big block versions such as the tube location?
    Scott Sims
    Texas Chapter
    • 43287
    Re: 1970 open air cleaner base
    Scott Sims
    Texas Chapter
    Scott-----
    The bases were the same for base engine, L-46, and LS-5.
    • D S.
      • March 1, 2005
      • 1551
      Thanks, Joe. I purchased an original open air cleaner base at a swap meet recently. I compared it to Paragon's base #2091 and the vent tube configuration appears different than mine. I believe that Camaro Z-28s had these, too. That's why I needed photographs for comparisons, if any.
        • 43287
        Scott-----
        Z-28 Camaros (as well as LT-1 Corvettes) used a different base. That's partially because they used a "high rise" manifold. Big blocks with a "high rise" manifold used the different base, too.
        • D S.
          • March 1, 2005
          • 1551
          Which base is this?
          • D S.
            • March 1, 2005
            • 1551
            • Timothy B.
              • April 30, 1983
              • 5202
              Scott,
              I have a 70 LT1 air cleaner and your base looks just like it best I can tell.
              • D S.
                • March 1, 2005
                • 1551
                Originally posted by Timothy Barbieri (6542)
                Scott,
                Thanks. I began to think the same after researching LS-5 and LT-1 air cleaner base photos. I picked up the original base and lid out of a box full of bases and lids at a swap meet for $20 hoping it was an original LS-5 base.
