69 rocker panel attachment - NCRS Discussion Boards
+ More Options
Posts
  • Brad S.
    • July 31, 2005
    • 227
    Does any one have a fix for replacing mangled molding stand off studs ( the studs that the screws attach to)? I have checked most of the usual vendors and cant find any replacements. Any help is appreciated.
  • Harmon C.
    • August 31, 1994
    • 3228
    Re: 69 rocker panel attachment
    If 68-69 use the same threaded screws as 73's at one time the vendors sold 5/16 bolts 1/2" long that were threaded in the center for the correct machine screw thread. They were installed by drilling out the stud to 5/16 and putting a nut on the back side. I made some with my drill press for my own use. When installed they are very had to see between the frame and the rocker panel but totally unlike factory studs. I retaped some studs also if they had metal to hold a screw.
    Lyle
    • Jerry B.
      • August 31, 1994
      • 416
      Hello, Today, I Removed My Rockers In Order Do A Little Spring Cleaning. The Rocker Fastners Remind Me Of The Ones Used On 58 Radio Dash Speaker. Check Out The Vendor Catalogs For A Picture.
      • Brad S.
        • July 31, 2005
        • 227
        Jerry, do your studs have the threaded stud coming out of the base? mine are so mangled that I don't even know what they are supposed to look like. Thanks Brad
