1962 gas tank ? - NCRS Discussion Boards
1962 gas tank ?
  • Bruce B.
    • May 31, 1996
    • 2930
    1962 gas tank ?
    Does anyone know the thread size of the gas tank drain in a 62 Corvette?
    Thanks.
  • Wayne W.
    • April 30, 1982
    • 3605
    Re: 1962 gas tank ?
    Thanks.
    Probably 1/8 pipe thread.
    • Barry H.
      • April 30, 1976
      • 213
      Re: 1962 gas tank ?
      Bruce, Fortunately I have my 62 on the lift for some Early Spring maint & cleaning. Wayne is correct, it is 1/8" pipe thread. Drain plug also has a 7/16" hex head.
      Barry Holmes
      • Bruce B.
        • May 31, 1996
        • 2930
        Re: 1962 gas tank ?
        Thanks guys.
        Bruce B
        • Mike M.
          • May 31, 1974
          • 8382
          Re: 1962 gas tank ?
          [quote=Barry Holmes (940);487715]Bruce, Fortunately I have my 62 on the lift for some Early Spring maint & cleaning. Wayne is correct, it is 1/8" pipe thread. Drain plug also has a 7/16" hex head.
          Barry Holmes[/uote]
          is the mfg logo FC or L ? is it a recessed hex head pipe plug? mike
          • Barry H.
            • April 30, 1976
            • 213
            Re: 1962 gas tank ?
            Mike, It has the 7/16" recessed head with no Mfr letters, (just plain). I have seen the FC & L markings on the 1/4" hex head pipe plugs used in the engine block drains. Hope that helps. Barry Holmes
            • Joe E.
              • April 1, 1985
              • 77
              Re: 1962 gas tank ?
              I have four tanks here that I had replaced and the one that I done reciently out of a one owner 62 has the plug that is pictured with the L. Another tank from a 62 that the current owner has owned since mid 70s had a plug with smooth head no recess. A plug from the tank of my 58 which I have owned since 67 has the L on it. The other tank from the 60 the plug was missing. All of the plugs are 1/8 pipe thread with a 7/16 head. Hope this helps Joe.
              • Bruce B.
                • May 31, 1996
                • 2930
                Re: 1962 gas tank ?
                Thanks to everyone.
                I checked the head marking on the gas tank drain on my 62 #5818 and it is marked "L".
                See picture below.
