62 Brake lights stopped working - NCRS Discussion Boards
  • John F.
    • March 23, 2008
    • 2424
    I was at our local Dairy Queen get together last night and getting ready to leave my buddies say I don't have brake lights. All lights work except the brake lights. I know there have been threads on this but I can't find it. Help.
    John F
  • Dan H.
    • July 31, 1977
    • 1372
    Re: 62 Brake lights stopped working
    Hi John, make sure your plunger switch on the brake pedal hasn't come loose and out of adjustment.
    Dan
    1964 Red FI Coupe, DUNTOV '09
    • John F.
      • March 23, 2008
      • 2424
      Plunger is tight and switch actuates.
      John F
        • 6959
        Dan, is the brake lamp switch powered up when you depress pedal both sides of harness?
        • Dan H.
          • July 31, 1977
          • 1372
          Yes, is always hot and harness connected to all tail lamps, switch completes circuit when pedal moves away from it. Lamps all need a good ground or will not complete circuit etc. to individual lamps. Ofcourse this all runs through the turn signal switch which is sometimes the fly in the bean soup!
          Dan
            • 6959
            Dan , how about if you wiggle the turn lever and maybe the harness under dash, but it certainly sould like a open in the switch.
            • Dan H.
              • July 31, 1977
              • 1372
              Ed, scroll down to bottom of this and surf the archive responses, happy hunting!
              • John F.
                • March 23, 2008
                • 2424
                The brake switch has power in and power out.
                John F
                • John W.
                  Administrator
                  • November 1, 1974
                  • 5109
                  John,
                  From the brake switch the power goes through the turn signal switch and then on to the lamps themselves. The left and right lamp are fed independently from the turn signal switch on. The turn signal switch turns off one brake lamp and uses it for the turn signal lamp. When the turn signal cancels it puts the brake lamp back in the circuit. Unusual for both lights to be kept of by the turn signal switch but I bet that is the most likely culprit.
                  Administrator
                  www.ncrs.org
                  • John F.
                    • March 23, 2008
                    • 2424
                    I pulled the steering wheel and took out the turn signal actuator ring. The flat verticle spring behind it was missing. Does anyone have one that I can buy? CC doesn't have them. Also I tried to clean up the parts. Can you lubricate with Sray-A-Lube graphite? How do you take out the switch from here?
                    John F
                    • Dennis C.
                      • June 30, 2002
                      • 888
                      John F
                      John,
                      Paragon has the flat spring, here is the link:
                      https://www.paragoncorvette.com/p-35...ng-spring.aspx
                      To remove the switch, take off the lower wiring cover, disconnect the wires and tape the ends. You might want to connect a drag line for re-installation, remove the two screws from the switch and pull it out.
                      Dennis
                      • John F.
                        • March 23, 2008
                        • 2424
                        Thanks Dennis, just ordered the spring and a new switch. Do you just unscrew the two screws and then unplug the wires under the steering column?
                        John F
                        • Dennis C.
                          • June 30, 2002
                          • 888
                          John F
                          John,
                          That's about it, you already did the hard work. I would suggest taping the ends of the wires to keep them flat and tie on a drag wire that will run up the column as you pull the switch wires out. The drag wire will make it a little easier to re-install the switch wires. You would reattach the wires to the drag (wire or string) and use it to snake the wires back in to position.
                          Dennis
                          • John F.
                            • March 23, 2008
                            • 2424
                            Starting to reassemble the turn signal switch. Have it in. I forgot to mark the steering wheel when I removed it. There are two guide pins of some sort on the down side of the steering wheel. Are they supposed to be in a certain position when putting the wheel back on the hub?
                            • Dennis C.
                              • June 30, 2002
                              • 888
                              There are two guide pins of some sort on the down side of the steering wheel. Are they supposed to be in a certain position when putting the wheel back on the hub?[/quote]
                              John,
                              They need to be on the left side of the hub when your in the driver's seat. The pins are what cancel the turn signals.
                              Dennis
