Thermostat Housing for a '63 300HP - NCRS Discussion Boards
  • Jon R.
    • February 8, 2010
    • 163
    I have a thermostat housing for a '63 300 HP engine. The housing has 'GM' and the number 3827369 debossed on the top. That is all. I have seen others that have an additional B2 or B4 or some other B#. Since mine does not have the B#, I was wondering if it would be correct. Why would it not have the B#?
    Thanks!
  • Irby G.
    • November 1, 2001
    • 267
    Re: Thermostat Housing for a '63 300HP
    I'm not exactly sure myself. I just wanted to send this back to the top to give someone else a chance to give ya an answer.
    Aloha,
    Irby
    • Donald L.
      • September 30, 1998
      • 461
      Thanks!
      I believe the iron thermo casting 33827369 is the correct housing for 63- 300 hp. The B # is the mold # for ID purposes in case of defect.
      • Jon R.
        • February 8, 2010
        • 163
        Donald,
        Thanks for the response. From the books, I know that the casting number is correct. I was wondering about what you called the mold number - the B#. Is it common for some housings not to have this mold number? Does this show that it is a repro? or later replacement casting? Or is it simply that some were just not cast with the number?
        Lastly, will this affect judging?
        Thanks!
        Jon
        • Jon R.
          • February 8, 2010
          • 163
          No more info? Anyone?
          • Harry S.
            • July 31, 2002
            • 5333
            April 20th 63. 3827369 with a B3.
