Corvette horns - NCRS Discussion Boards
Corvette horns
  • D S.
    • March 1, 2005
    • 1551
    Re: Corvette horns
    Originally posted by Jack Humphrey (17100)
    Here's pix of a '2 F 3' dated '032 horn...
    Thanks, Jack! That is exactly the horn I got off of eBay. This is going to make Don Cast happy.
      • 15599
      Re: Corvette horns
      Originally posted by Steven Gochenour (49707)
      After looking at Jack's pic., I noticed my 72' terminal is at a different location, the mounting bracket is not rivited but has a large nut that can be loosened to relocate position or removed bracket and the housing is designed different. Maybe a service replacement causing the difference or at lease two different designs for 72' ?? Steve
      The large nut is generally regarded as an indicator of a service replacement horn. The replacement horns usually are provided as a kit with several mounting brackets. One choses the proper mounting bracket and orients the horn as necessary, and bolts them together. Thus one kit can fit many applications.
      • D S.
        • March 1, 2005
        • 1551
        #18
        Re: Corvette horns
        Steve & Terry,
        I'm not where I can examine the horn tonight but I believe the horn mounting arm is factory fixed, not a kit. The part number 9000 last 0 is over-stamped with 032. The date appears to be 1G3. I will reply to this tomorrow after I take a closer look at it and post a photo of it.
        • D S.
          • March 1, 2005
          • 1551
          #19
          Re: Corvette horns
          Here is the photo of the 032 horn that is the subject of this post:
          • Kurt G.
            • April 30, 2005
            • 343
            #20
            Re: Corvette horns
            Scott,
            The horn on you '72 is the correct one. The '72 horn is larger than the '70-'71 horn, and a much wimpier sound. My original horn sounds more like the horn off a model A than off a "modern" car. Kind of a boop, boop sound instead of a loud "honk". Physically, the horns "look" the same, but the '72 is smaller.
            Kurt Geis
            Chairman, Midway USA Chapter
            Targa Blue 1972, Top Flight and Duntov Award, 2014
            Arctic White 1994, Top Flight, Hrt. of Amer. Reg. 2011
            Arctic White 2013 60th Anniv Special Edition Conv.
            • D S.
              • March 1, 2005
              • 1551
              #21
              Re: Corvette horns
              My 1970 with the two horns sounds great. I can't imagine why GM would want to go with one horn in 1972 that, according to some here, sounds that weak.
              I paid less than $20 including shipping for the horn off of eBay. The seller had it listed incorrectly as an 072. The seller posted a correction after I questioned it being an 072 Corvette horn for a 1972. It was still painted over so it was hard to tell even from the close-up photos. After I received it I used lacquer thinner to be able to see the numbers and date of 1G3.
