finish for the steering power cylinder bracket straps - NCRS Discussion Boards
  • Steve L.
    • June 30, 2001
    • 763
    These are the straps(about 3 inches long) with the 2 studs that hold the bracket to the frame. The power cylinder rod attaches to this bracket.
    My list, that I put together based on ongoing NCRS posts, shows it as black phosphate. I'm wondering if it should be natural. Same for the nuts.
    This is for a 73
    Steve L
    73 coupe since new
    Capital Corvette Club
    Ottawa, Canada
    • 43289
    Re: finish for the steering power cylinder bracket straps
    This is for a 73
    Steve------
    I wouldn't be too concerned about the finish on these reinforcement plates. They cannot be seen when installed on the car. The later GM pieces used for 1979-82 and also SERVICE for all 1963-78 were painted semi-gloss black. The earlier piece was either natural or black phosphate, I don't recall which.
    The attached studs were black phosphate. I believe the nuts were, too, but I can't recall, for sure.
    • Steve L.
      • June 30, 2001
      • 763
      thanks Joe
      I'll add this to my list
      Steve L
      73 coupe since new
      Ottawa, Canada
        • 43289
        thanks Joe
        Steve-----
        I checked and the GM #102634 nut used to attached the frame bracket was a 5/16-18 thread size and 17/64" thick. It was GM 286M material (SAE grade 5) and had a "plain" (i.e. natural) finish. It was once available in SERVICE but is no more.
        The GM #102320 lockwasher was 5/16" ID, 19/32" OD, and 7/64" thick. It also had a "plain" finish.
