Another C1 ballast resistor question - NCRS Discussion Boards
  • David Z.
    • February 13, 2009
    • 50
    Hello All, I have a 1960 Hi Horse Fuel Car and am using a 107 coil....I have recently switched over to a breakerless SE system, My question is, having done that, I obviously do not have to remain concerned about burning points out so what if anything could I expect to gain if I swap out the ballast resistor to the lower value ? ie from 1.8 ohm version to the .3 ohm version..??
    thx, Dave.
  • Timothy B.
    • April 30, 1983
    • 5203
    Re: Another C1 ballast resistor question
    David,
    I think it's a good idea to use the .3 ohm resistor but I would call M&H, (the company that makes the breakerless SE) and ask them first before changing.
    Post what they tell you because I would like to know for myself.
    The more primary current you give the coil the hotter the spark.
    • David Z.
      • February 13, 2009
      • 50
      OK, just off the phone with M&H.... they state that I should stay with the higher value ballast resistor as going to the .3ohm version would possibly shorten the life of their internal module. Good enough for me. thx, Dave.
      • Timothy B.
        • April 30, 1983
        • 5203
        Thanks David,
        I appreciate you posting there response. I am sure others here would like to know also..
        • Jack H.
          • April 1, 1990
          • 9906
          I'd suggest that if you're going to run the car with the 1.8 ohm ballast and the Breakerless SE system, why not conserve/preserve your rather rare factory original Delco Remy '107 coil?
          You won't see a performance difference if you decide to install a later era '202 coil. Plus, if factory source authenticity isn't important to your driver vs. show engine configuration, consider a NAPA aftermarket ignition coil...
          • David Z.
            • February 13, 2009
            • 50
            Thanks for the pointer Jack, even though my 107 coil is a repop, its more costly to replace than a NAPA part... Sound advice,cheers, Dave.
            • Timothy B.
              • April 30, 1983
              • 5203
              David,
              Plus, the NAPA coil will not fail and leave you.
