70 L46 distributor installed position - NCRS Discussion Boards
    • 15703
    #31
    Re: 70 L46 distributor installed position
    You're probably correct. At first I typed CW, then changed it. It's been about five years since I pulled a distributor, so I probaby forgot.
    • Bill L.
      • February 1, 2004
      • 1403
      #32
      Well just a follow up. Well apparently all is well. I ended up with just enough room when I tried to set the timing again. The vacuum advance is close but it will clear by just a little. The advance is behind the support and the tach cable is coming out correctly as well.
      I thank every one for all their help.
      The shop did have the gear installed correctly.
      Bill
        • 15606
        #33
        Bill
        I am glad it worked for you Bill. Thanks for posting your results. It always makes us feel warm and fuzzy when we see a successful conclusion.
