C3 ignition shielding - NCRS Discussion Boards
  • Jim M.
    • February 23, 2009
    • 233
    Other then the main cover for the distributor, are the verticle and lower pieces the same for a 69 as they are for a 77?
    • 6948
    Re: C3 ignition shielding
    The vertical sheilds should be the same, but the lower v-sheilds are different for 69 , did not have the safety engine mount,hence the mounting was different.
    • Jim M.
      • February 23, 2009
      • 233
      Edeard, what is the "safety engine mount"? Jim
        • 6948
        Jim, the 69 motor mount did not have a safety catch if the mount failed, in that era when the car was accelarated the engine would pick -up and the throttle would get stuck ,sometimes wide open depending on how hard you accelarated the car. in 70 GM switched to a safety catch on the mount in case it failed. GM did recall quite a few cars to install a safety cable to stop the engine from picking up of the mount when they failed.
