Underneath color - NCRS Discussion Boards
Underneath color
  • Gary L.
    • April 26, 2010
    • 18
    Underneath color
    Hey after 45 years i finally get my dream car, a 72' bumper car, and I am knew to NCRS. My restoration question is color for frame,engine compartment,and under side of body. Gloss black,Semi gloss,Green primer? Thanks.
  • Russ S.
    • April 30, 1982
    • 2163
    Re: Underneath color
    Gary, The underside was unpainted and the rest was semi gloss.
    • Gary L.
      • April 26, 2010
      • 18
      Thanks. I really appreciate it.
      • Michael F.
        • 745
        Gary, order a judging manual for the car and it will tell what you need to do to return to factory, also several books bookstores can get you or ncrs to help, good luck and congrats on car
        Michael
        70 Mulsanne Blue LT-1
        03 Electron Blue Z06
        • Tom H.
          • December 1, 1993
          • 3440
          Hey Gary !!!
          Welcome aboard !!!! Congrats on the new ride. If your car is super original, you might want to have your local chapter check it out before painting, cleaning and detailing. How about posting up a picture of your new car !!!
          Tom Hendricks
          Proud Member NCRS #23758
          NCM Founding Member # 1143
            • 3416
            Hi Gary,
            Welcome, and I think it's great that you've found your dream car.
            Along with Michael, I'd suggest you buy a copy of the 70-72 TECHNICAL INFORMATION MANUAL & JUDGING GUIDE to help determine just how original your car might be. There are 2 other publications you might want to buy to help you learn about and work on your 72. The AIM (ASSEMBLY INSTRUCTION MANUAL), and the GM CHASSIS SERVICE MANUAL. All are available from the NCRS store.
            I'd enjoy seeing some pictures too.
            • Lynn H.
              • December 1, 1996
              • 514
              Gary, I too, would like to extend a welcome to the group. LOTS of great advice (almost too much to comprehend), but as already suggested, some research material from the NCRS is a great start. You will also find loads of good info by searching the archives for past threads. It truly is a sickness most of us are glad to have, and there is all the help you will ever need in this group. Congrats and good luck with your "dream car"!!!
              Lynn
              • Gary L.
                • April 26, 2010
                • 18
                Thanks for everyone's help.
                • Kenneth T.
                  • March 23, 2008
                  • 631
                  Welcome, Gary!
                  All the above is good advise. There is so much knowledge here to benefit from. One small thing though, SAVE EVERYTHING from your car. You will be looking for it later as dated and original parts are more and more difficult to come buy. What color?
                  Ken
                  • Tom S.
                    • March 1, 2004
                    • 1087
                    I agree order the judging manual.But you will still need help from this board. It is unbelieveable the amount of knowledge here. And welcome aboard. Tom Stanton #41491
                      • 11669
                      Follow the link in my signature below to find a few hundred pictures of my very original 1972. You will find a lot of answers to simple questions by looking there.
                      Patrick
                        • 43248
                        Patrick
                        Patrick------
                        All these photos and not a single one of the right rear spark plug HEAT shield. Of course, it's covered by the right rear RF shield. Do you know if the heat shield is the type with the large hole in it, or not?
                        Also, something I happened to note in one of your other photos. Your harmonic balancer is interesting. It's not the one I would expect on a 1972 base engine. This balancer is a GM #3947704. It's 8" OD X 1-5/16" thick. This balancer was used for 1969-71 base engine but, according to GM as well as some past observations I've made of 72's, the 1972 base engine used balancer GM #6272221. This was a 6-1/8" balancer.
                        Is your car an early 72 that might have used the 71 balancer?
                        • Gary L.
                          • April 26, 2010
                          • 18
                          Hey Alan,try this: Gary.Leber@packersplus.com
                            • 11669
                            Patrick------
                            Joe,
                            Late 72, June of 72 build.
                            Heat shield has (IIRC) the hole just like my 71.
                            Patrick
                              • 43248
                              Joe,
                              Patrick
                              Patrick------
                              That balancer REALLY surprises me. Anyone else out there have a 1972 base engine with an 8" balancer?
