steering box fluid - NCRS Discussion Boards
steering box fluid
  • Robert K.
    • November 17, 2009
    • 64
    steering box fluid
    Can anyone tell me what is the correct steering box fluid? Were having different opinions on 80-90 gear fluid or grease? Note it is not power steering...
    Thanks....
  • William C.
    • May 31, 1975
    • 6037
    Re: steering box fluid
    Service manual says EP Chassis Lubricant.
    Bill Clupper #618
      • 43259
      Thanks....
      Robert------
      The original lubricant was GM #1052084. This was a grease. GM #1052084 was discontinued quite a few years ago and replaced by GM #12377985, a multi-purpose chassis lubricant. This is what I use and recommend for most chassis lubrication except wheel bearings.
      Most other GM manual steering gear boxes used a different lubricant. It was GM #1052182. This was ABOUT a 90 wt viscosity. This is the reason for the confusion relative to the correct steering gear lubricant.
      • Edward J.
        • September 15, 2008
        • 6950
        Robert, the chassis lube GM part no. is 12377985
        • Gary R.
          • April 1, 1989
          • 1804
          If you use gear oil it will leak out almost for sure. Some greases separate more then others and I've had a small number weep oil through sealant.
          There is another thread going on now about box greasing as well.
          • Robert K.
            • November 17, 2009
            • 64
            Thanks didn't see it in the 63 service manual, GM manual what page? Is that Grease? What Does EP stand for?
              • 43259
              Robert------
              Yes, it's grease. "EP"= "Extreme Pressure"
