Oil pan question. - NCRS Discussion Boards
Oil pan question.
  • Bruce B.
    • May 31, 1996
    • 2930
    Oil pan question.
    Can someone identify this oil pan part number 539937?
    It is a single step trapdoor pan.
    Seems like a replacement midyear pan.
    Thanks.
    • 43234
    Re: Oil pan question.
    Thanks.
    Bruce------
    There was NEVER a Chevrolet oil pan of GM #539937. However, there was a Corvette oil pan of GM #359937. It was a SERVICE-only oil pan applicable to 57-62 Corvettes. It's basically the same as the 1962 Corvette oil pan with a front seal radius of the 1975+ size and uses 75+ gasket set..
    • Bruce B.
      • May 31, 1996
      • 2930
      Joe,
      Dyslexia got the best of me, the part number is what you stated.
      359937 Group 1.426.
      Pictures are on Ebay under item number 160427661306
      The pictures show the pan as a single step pan. Was this a redesign of the 3 step pan?
      Will that work ok in a C1 Corvette ? I thought there were some clearence problems.
        • 43234
        Joe,
        359937 Group 1.426.
        Bruce------
        What we have here is a GM #359937 BOX which contains a GM #359942 OIL PAN. The GM #359942 is the 63-72 "6 quart" SERVICE small block oil pan.
        • Bruce B.
          • May 31, 1996
          • 2930
          Joe,
          Thanks.
          Bruce B
