1969 Vacuum Relay Valves - NCRS Discussion Boards
  • Bill S.
    • August 31, 1999
    • 104
    How many headlamp vacuum relay valves are there on a early 1969 Corvette?
    They are located by the headlamps.
    A schematic or a picture is greatly appreciated.
    Thanks in Advance
    Bill Schroeder
    #32882
    • 6942
    Re: 1969 Vacuum Relay Valves
    Bill, there are two relays mounted under the middle front of the top surround panel.
    • Jerry B.
      • August 31, 1994
      • 416
      There Are Two, One For The Headlights And One For The The Wiper Door. There Are Many Articles In The Past That Discuss This Subject. I Maybe Able To Help. I Just Spent A Week On My 69 System.
        • 15601
        Thanks in Advance
        Bill Schroeder
        #32882
        Define early.
        Around October 1969 they went to two relay valves for the headlamps. Before that, or close to it, there was just a single valve.
        • Joseph K.
          • August 26, 2008
          • 407
          I agree with Terry, I have a 69 that was made on July 18th 1969 and there is only one control valve located in the center of the nose of the car. If you on line you can find diagrams of the headlight and wiper systems. I have one at home but can't get to it for a couple of days.
          Joe
          • Phil D.
            • January 17, 2008
            • 206
            Mine was made in late November 69 and has just one valve in the nose. I can't say that nobody changed it after the fact, but given that the hoses appeared original and hardened, I doubt it. I just spent some time tracking down vacuum leaks and getting my system working again.
            • Richard D.
              • December 1, 2002
              • 328
              Thanks in Advance
              Bill Schroeder
              #32882
              Had this diagram on my computer. Maybe it will help. Rich
              • Joseph H.
                • December 11, 2007
                • 159
                I have a sept' 68 build (early) and 1 valve under the nose and the other is under pass fender. I to spent much and money getting my system functioning again as virtually every component was leaking vacuum.
                • Dick W.
                  • 10483
                  I believe that your car should have only one valve.
                  Dick Whittington
                  • Don W.
                    • September 30, 1997
                    • 492
                    Also, Dr Rebuild sells a great laminated 12 X 18 diagram covering headlights and wiper vacuum systems with a seperate document on each parts location, function and the method to test it's proper function.
                    Web catalog of 700+ pages, 1000+ illustrations, 12,000+ Corvette restoration parts available mail order. Dr Rebuild Corvette Products manufacturing & distributing parts for 1953-1982 models for 22 years.
                    Web catalog of 2000+ pages, 1000+ illustrations, 12,000+ Corvette restoration parts available mail order. Dr Rebuild Corvette Products manufacturing & distributing reproduction parts for 1953-1982 models since 1979.
                    Good luck...Don
