70 RC 15 cap and MC cap - NCRS Discussion Boards
  • Bill L.
    • February 1, 2004
    • 1403
    After a review of the archives no one makes a 100% reproduction of either. No surprise there.
    Who makes them the closest. There is a beautiful RC 15 on ebay for $185 that I just cannot afford at this point. Same with the correct MC cap.
    How close is the De Witts RC 15 cap? How close is the Lone Star MC cap?
    Thanks guys.
  • Edward J.
    • September 15, 2008
    • 6960
    Re: 70 RC 15 cap and MC cap
    Bill, Dewitts is the closest you will find, all the others may purchase from the same supplier. 185. sound like alot for so little gained with the points. I would wait and if your a carlisle attender do some searching there.
    • Paul O.
      • August 31, 1990
      • 1716
      Bill all Reproduction RC-15 will lose points on the judging field. It really comes down to Configuration of the cap and in some cases the finish. For Config it the letters, the indented center area, shaping around the side edges and the rivet. If the finish is not typical then the item will lose 50% of its originality points. Some are better then others but most that I have seen will lose 50%.
      That on the top side if you remove the cap for a judge there will be more issues.
      As far as the M/C cap goes there maybe no deduction but as in all cases is determined by the knowledge of the judges. There are some small Config and some finish issues for those caps.
      Paul 18046
        • 11698
        Not correct.
        DeWitts does not manufacture or have manufactured any radiator caps.
        And, the one they sell is not the most correct, at least for RC-15s.
        Check out these:
        as well as Long Island Corvette Supply.
        Both carry caps much better than the one 95% of the Corvette repo houses sell.
        • Mark D.
          1984-96 Team Leader
          • June 30, 1988
          • 2179
          Plus, you can probably get it by the guys that judge 70-72 at Bloomington. I know them and they probably wouldn't catch it.
          Mark
          Kramden
            • 15645
            Mark
            I resemble that remark.
              • 11698
              Mark
              Yep.
              Too bad it won't be me.
                • 15645
                Yep.
                You would not have been judging radiator caps anyway Doc. Unless you know more about my lifespan than I do.
                • Mark D.
                  1984-96 Team Leader
                  • June 30, 1988
                  • 2179
                  You would not have been judging radiator caps anyway Doc. Unless you know more about my lifespan than I do. :Stick Out Tongue:
                  I'll bet when the cap was judged, he would have uncorked his big ol head out of the interior and made a nuisance of himself.
                  I'm sure we will see you in a white cap before it's all over.
                  I'm going to bed, I've got to fly a jet tomorrow...
                  Kramden
                    • 11698
                    When was the last time I didn't take a look at a radiator cap???
                    • Kevin G.
                      • February 1, 2005
                      • 1084
                      At a recent chapter meeting a member spoke about a problem he was having with these imported/aftermarket radiator caps. Apparently the bottom piece pop's off with ease. The lower piece from his cap, on his 67 bb, was later found in the water pump blocking most of the coolant flow causing the car to overheat!
                        • 15645
                        If you were judging Interiors at Bloomington Gold I could count 10 cars you would not have the time -- at least not during judging -- and there is not much time to the rest of the day when there are ten cars to judge there.
                        • Edward J.
                          • 6960
                          Not correct.
                          Check out these:
                          Patrick, what is the difference in the cap from dewitts and old car stuff, they seem to look the same.rivit, plating, marking.
                            • 11698
                            Totally different with respect to details.
                            Get one of each in your hand and it's no comparison (unless, by chance, DeWitts recently changed the source they've always used and went with OldCarStuff).
