57 crossover - NCRS Discussion Boards
57 crossover
+ More Options
Posts
  • Chris S.
    • March 28, 2007
    • 139
    57 crossover
    is the crossover pipe for the fuel injection exhaust systems sealed, welded, or just fitted on the center joint where the two meet?
  • Gary C.
    Administrator
    • October 1, 1982
    • 17768
    Re: 57 crossover
    Chris, a fitted connection with muffler sealer part # 1459764 per the AIM. Gary....
    NCRS Texas Chapter
    https://www.ncrstexas.org/
    • Bruce B.
      • May 31, 1996
      • 2930
      Re: 57 crossover
      Chris,
      I agree with Gary,
      No clamps, just some silicate muffler sealer or muffler cement.
      When you go to assemble it be sure you do a test fit first since once assembled the sealer hardens pretty quickly. Also wipe the wet cement with a damp rag before it drys or it will never come off.
      Once assembled it will last forever.
      Good luck.
      • Chris S.
        • March 28, 2007
        • 139
        Re: 57 crossover
        thanks guys.
        • Mike M.
          • May 31, 1974
          • 8400
          Re: 57 crossover
          the cross-over pipes i got from corvette central were such a precise fit, i had no need to seal the joint with cement. absolutly no exhaust gas leakage at the joint with cc's precise fit. the advantage will be evident if i have to dis-assemble the joint in the future.mike
          • David B.
            • July 31, 2004
            • 330
            Re: 57 crossover
            Same experience as Mike's with the parts I got from Allen's Stainless. No sealer needed for a tight fit.
            Dave, 1969 427, 1957
            Previous: 1968 427, 1973 454
            • Chris S.
              • March 28, 2007
              • 139
              Re: 57 crossover
              mine does fit tight too. wasn't sure if it was required no matter what.
              • Stuart F.
                • August 31, 1996
                • 4676
                Re: 57 crossover
                I thought the idea of the slip fit joint w/o sealer was to allow for some level of expansion/growth when hot. Don't recall using any sealer back in the day for just that reason.
                Stu Fox
