Which screw is this? - NCRS Discussion Boards
  • Chris E.
    • November 3, 2006
    • 1335
    I'm missing a screw (both driver and passenger side) on this bracket for the convertible top. I looked at both Paragon and Long Island. I'm still not clear on what screw I need to order.
    Thoughts?
    Chris Enstrom
    2011 Z06, red/red
  • William C.
    • July 15, 2009
    • 239
    Re: Which screw is this?
    Chris..The weatherstrip should have a tap on it that this screw holds. Search "convertible top rear bow" By Bill Trinka and you should get your answer..Bill
    • Alan D.
      • January 1, 2005
      • 2053
      Here is an original Mar64 - it may help if no changes made to the area.
      Appears to be a piece of metal from gasket.
      • Michael D.
        • February 1, 1978
        • 159
        Chris
        It looks like you are missing a piece of weatherstrip that has the tab which the screw goes through. It is small pan head screw/ phillips/ about a # 4 or #6 X3/8 inch
          Chris -
          The molded filler piece that forms the front of the top frame lower side weatherstrip has a molded-in steel reinforcement with two tabs for the attaching screws; you appear to be missing those filler pieces. See photo below.
          • Chris E.
            • November 3, 2006
            • 1335
            Yup, I just put two and two together and figured that out. I knew that I had yet to install those rubber pieces. I haven't yet because I didn't want them scraping on the paint on the top of the door.
            Thanks guys.
            Chris Enstrom
            2011 Z06, red/red
