Gen III Head Bolt Length - NCRS Discussion Boards
  • Steven B.
    • June 30, 1982
    • 4018
    I believe all Jan 2004 blocks thru Gen IV used 11 mm head bolts. What length did pre Jan 2004 Gen III blocks use?
    Thanks!
    Steve
    • 43290
    Re: Gen III Head Bolt Length
    Thanks!
    Steve
    Steve------
    They use 3 different bolts. There are ten M8X1.25X45 mm; sixteen M11X2.00X155 mm; and four M11X2.00X100 mm.
    I'm not so sure that the 2004+ Corvette engines are actually Gen IV. It's my understanding that Gen IV engines have "cylinder deactivation" and I don't think that Corvette engines, even to this day, have that feature.
    Addendum: apparently, the Corvette engines were changed from Gen III to Gen IV in 2004. When the Gen IV small block was first introduced, I believe that all versions had cylinder deactivation. At some later time, I guess that the Gen IV must have been made both with and without cylinder deactivation because I don't think that Corvette engines have that feature.
    • Clem Z.
      • January 1, 2006
      • 9427
      Steve------
      the corvette use the same cylinder case but not the the cyl deactivation
      • Steven B.
        • June 30, 1982
        • 4018
        Thanks!!!
        Steve
