I ran a compression check on my engine today (L72). I have been concerned about possibly using too much oil. A quart every 5-600 miles. I posted a few weeks ago that I get a dry residue on the lower rear quarters anytime I take the car out. I was trying to figure out if it was fuel or oil related. I also did a leak down test on two of the cylinders; I just did not have time to do them all. Results follow:
Compression Leak Down
#1 185 5% differential at 100 P.S.I.
#2 200 5% differential at 100 P.S.I.
#3 185
#4 180
#5 190
#6 180
#7 190
#8 190
There was a hiss coming from under the valve cover. I assume that is normal since the pressure has to go somewhere, is that correct?
I will run the leak down test on the other cylinders, but assuming they come in anywhere close it seems to me I have a pretty tight engine. 200 seems a little high on #2, I am guessing it could be due to the excess oil I am getting in that cylinder. Presumably the engine has about 3500 miles in the last 10 years.
My next move is probably to pull the springs, check the valves to see if they are loose and put on new seals. Maybe the limited use in the past ten years has allowed the seals to dry out?
I would appreciate any thoughts and suggestions.
#3 185
#4 180
#5 190
#6 180
#7 190
#8 190
